Activity Forums DVD Authoring Audio Tracks in Scenarist
  • Audio Tracks in Scenarist
    Posted by Victoria Ellis on January 7, 2008 at 9:42 pm
    I am trying to author a DVD in Scenarist where, on the title menu, there is an option to play the video track without an audio commentary, or with it.
    I have imported both audio streams into the video track, but I cannot figure out how to make the “play with audio commentary” button play the video with the audio 2 track.
    Can anyone tell me how to do this, or have any suggestions on how to change the menu structure so I can?
    Many thanks,
    Victoria
    Clint Nitkiewicz hernandez replied 18 years, 7 months ago 4 Members · 5 Replies
  • Eric Pautsch
    January 7, 2008 at 10:44 pm
    There are several different way to do the same thing in Scenarist but this is the way I do it:
    Since your in the VMG, you can’t set the audio stream from there. I’d give a register a value depending on which button was chosen. Then set the stream playback in the Pre-Command of the PGC which contains the movie based on the value of the register.
  • Max Kovalsky
    January 8, 2008 at 1:42 am
    That’s what I’d recommend as well. Except if you want to track your setting when jumping back and forth within VMG, I’d write variable, set stream in the post-command of your menu, and enforce the setting again in the pre-command of your title PGC.
    Max
    Author
    New York
    Area4.tv
  • Victoria Ellis
    January 8, 2008 at 9:11 am
    Thanks – theoretically that makes sense, but how do I actually do that? Sorry, but I haven’t done any complicated projects before!
    Thank you!
    Victoria
  • Max Kovalsky
    January 8, 2008 at 11:31 am
    In your button commands do this:
    1. Mov GPRM 1, 0, link indirect, post-command of this PGC
    2. Mov GPRM 1, 1, link indirect, post-command of this PGC
    GPRM 1 not effectively carries your setting.
    In the post-command of that PGC (your menu), do this:
    1. Set audio stream to GPRM 1, link to title
    In the pre-command of your title PGC, do this:
    Max
    Author
    New York
    Area4.tv
  • Clint Nitkiewicz hernandez
    January 18, 2008 at 12:39 am
    Hey Victoria, have fun with the links below. They should help a lot.
    Check out the other pages also for reference.
    https://www.dvd-replica.com/DVD/setstn.php
    https://www.dvd-replica.com/DVD/vmgroups.php
    Good luck.
    Clint Nitkiewicz Hernandez
    http://www.newelementproductions.com
    Film-Maker/ Blu-ray Author/ Compositor
