Activity › Forums › Adobe Premiere Pro › Audio Tracks in Premiere
  • Audio Tracks in Premiere
    Posted by Ralph Smith on October 31, 2008 at 11:20 pm
    Hi all,
    We’ve just done a shoot with two mics (a lavlier tie clip and a boom mic) each individually feeding into the Sony DSR450 camera.
    I captured the video from the DV tape as DV AVI using a basic video capture software (not Premier).
    I was told by the soundman that when importing the AVI in Adobe Premiere, the audio would appear on two seperate audio tracks for each mic (so we could switch between them, or choose the best recording).
    Having put the audio into Premiere, I see one audio track with a Left and Right channel. Is it possible to listen to each mic track or:
    i) have the two mic tracks been mixed into one audio track when fed into the camera or;
    ii) When capturing the video, should it have been done a different way to seperate the audio onto two tracks? or
    iii) When choosing to import in Premiere, is there a speical setting which tells the audio to seperate two different tracks?
    The problem we have is there is a lot of background noise from outside the room we filmed in – mainly passing car traffic. If this audio is all we have to work with, any ideas how to lose this background noise within Premiere, or do we have to use some audio software to cut out low frequencies?
    Any ideas appreciated!
    Ralph
    Hector Melendez replied 17 years, 10 months ago 3 Members · 3 Replies
  • Mike Velte
    November 1, 2008 at 11:21 am
    In the Project window, select the video clips and choose Clip>Audio Options>Breakout to mono. This will give you 2 separate audio tracks to work with.
  • Ralph Smith
    November 2, 2008 at 9:12 pm
    Thanks Mike – life saver!
    Having checked there is still a lot of background noise, although not as much on one of the mics. Do you typically pick up more ambience witha tie-clip mic or boom? Not sure which was which.
    Has anyone had more joy with either Audition or Soundforge for removing low frequency noise?
  • Hector Melendez
    November 15, 2008 at 12:29 am
    Me too use 2 separate mics; one for each input. When editing, in the timeline I use >fill left or fill right depending of the track I want to rave. This convert a st. track into mono (left or right)
    This is found in the “audio ST. effects” folder. Here also you will find other effects to vary the audio. You have to “play with” to find out what best suit your needs.
