Activity › Forums › VEGAS Pro › Audio tracks gone off the rails
  • Audio tracks gone off the rails
    Posted by Paul Gregory on May 1, 2014 at 8:12 am
    I seldom use much original sound but rely more upon natural sounds or music. I’m having problems with current project & I think its because the audio track is now a mess. It started out with the usual 1 video & 1 audio track. I wished to insert an audio volume envelope but this didn’t happen.
    Then I a saw I had a master bus. I clicked various tabs to get rid of it but only made things worse. How do I get everything back to the way it should be?
    Thanks in advance
    Mike Kujbida replied 12 years, 4 months ago 3 Members · 4 Replies
  • Graham Bernard
    May 1, 2014 at 9:13 am
    Post a screengrab of your workflow so far.
    G
  • Mike Kujbida
    May 1, 2014 at 11:00 am
    The shortcut key for a volume envelope is the letter v while the shortcut key for an audio master bus is the letter b.
    They’re right next to each other so it’s an easy mistake.
    Press b again and the audio master bus will go away.
  • Paul Gregory
    May 2, 2014 at 1:27 am
    The shortcut key make an easy change & I added the volume envelope. Unfortunately I then right clicked on the track & told it to combine the tracks. It said that this worked but all places where I had set sound to zero the sound could still me heard. I suppose it might have been different if I had combined the tracks first. The current audio track is labeled as Microsoft Sound mapper.
    Thanks in advance
  • Mike Kujbida
    May 2, 2014 at 10:21 am
    ” It said that this worked but all places where I had set sound to zero the sound could still me heard”
    Very strange. I do this a lot and never hear any audio. Was it a stereo track or dual mono (i.e. two two distinct channels on a single stereo track?)
    “I suppose it might have been different if I had combined the tracks first.”
    That’s a possibility. Once again, what was on the track?
    ” The current audio track is labeled as Microsoft Sound mapper.”
    You choose your sound card in Vegas Preferences.
    Options – Preferences – Audio Device.
    Mine changes back to Microsoft sound mapper all on its own so I have to keep changing it back to what it’s supposed to be.
