Activity Forums Apple Final Cut Pro Legacy Audio tracks – bug???
  • Audio tracks – bug???
    Posted by Thomas on July 24, 2007 at 8:31 pm
    Have you guys encountered a problem where when you add more audio tracks for example 6 or 8, when ever you drag clips with audio from the bin into the timeline, the audio of the clips fill up the 6 or 8 audio tracks when it actually only has 2?
    Is there a setting or is this a bug?
    Thomas replied 19 years, 2 months ago 2 Members · 2 Replies
  • Walter Biscardi
    July 24, 2007 at 9:26 pm
    Nope. If all those audio tracks are there, then you digitized that many tracks.
    With the AJA Kona for example, I can digitize 16 channels of audio in realtime during capture. Even if my source only has two channels of audio present, if I don’t set up my Capture Settings correctly in the Log and Capture window, I will end up with a clip that has 16 tracks of audio. Only 1 and 2 will actually have sound and the rest will be silent.
    If I simply drag one of those clips from the Browser to the timeline, all 16 tracks of audio will follow.
    Walter Biscardi, Jr.
    HD Editorial & Animation for Broadcast and independent productions.
    All Things Apple Podcast! https://cowcast.creativecow.net/all_things_apple/index.html
    Read my blog! https://blogs.creativecow.net/WalterBiscardi
  • Thomas
    July 24, 2007 at 10:12 pm
    Thanks Walter, you’re right.
    This is my first time working with a couple of Assistant Editors, who are pretty new at this. So I have to always go back to square one and figure out what they’re doing wrong myself.
    Kind of defeats the purpose, which takes editing time away.
