Activity Forums Apple Final Cut Pro Legacy Audio tracks
  • Posted by Anna Little on April 22, 2010 at 5:53 am
    Hello
    I’ve been capturing footage from my Sony Z7 on to FCP 7 and the audio tracks are not split when I place the soundbites on the timeline. The tracks are split on the camera and appear split when I open up audio mixer….
    Can anyone help me with this – it hasn’t done this before.
    Thanks, Anna
    Anna Little
    Anna Little replied 16 years, 4 months ago 2 Members · 2 Replies
  • Andy Mees
    April 22, 2010 at 7:36 am
    Hi Anna
    The default state for the grouping of your master clip audio, either Dual Mono or Stereo, is defined by your Clip Settings during capture …
    In the Log and Capture window, under the Clip Settings tab you can click on the audio link button at left of each source audio pair to toggle between Mono and Stereo.
    Once captured you can toggle the status of an audio pair in the timeline by using the Modify > Stereo Pair command (Opt L)
    Hope it helps
    Andy
  • Anna Little
    April 23, 2010 at 7:44 am
    Lovely – thank you SO much!
    Anna
    Anna Little
