Activity Forums Adobe Premiere Pro audio track
  • audio track
    Posted by Ilan Eran on July 29, 2011 at 8:22 am
    I use premiere cs4, Although I put a clip on Video tracs 1 & 2,
    all the audio clips appear on Audio track 4, and I cant move any of them to other track. What do I do wrong?
    I.E
    Jon Barrie replied 15 years, 1 month ago 3 Members · 2 Replies
  • Alex Udell
    July 29, 2011 at 6:23 pm
    Audio in PPro can be Mono, Stereo or 5.1.
    So there is a mistmatch between your source type and the tracks you are tying to put it on.
    see this:
    https://www.video2brain.com/en/videos-4009.htm
    Alex
  • Jon Barrie
    August 1, 2011 at 1:17 am
    Chances are the default settings for sequences are being used and they are for 3 Stereo Audio Tracks. The footage you are using is most likely Mono or 5.1 and in order to add these audio clips to the sequence a new track that matches the audio type is created on track 4.
    To clean up the space you can right click on the track names area and select delete tracks, then tick the all empty tracks box and OK, the tracks that have nothing on them will be removed and you can see your working tracks at the top of the Audio Track UI again. 🙂
    This works for Video Tracks too.
    – JB
    Jon Barrie
    aJBprods
    Jon’s YouTube Tutorial Page
    follow Jon with twitter
