Activity Forums Adobe Premiere Pro Audio track moves with out the levels!
  • Audio track moves with out the levels!
    Posted by Bruce Klein on February 20, 2012 at 7:30 pm
    REPOSTED:
    Having completed an entire piece I need to remove the bars/tone/leader, and I need 5 seconds of black in the beginning.
    When I attempt it, one music tracks levels moves out of sequence. In other words, the levels stay where they were and I really do not want to re do all the levels. I know there is a way to move the track in total with the levels moving with it. I can’t seem to get it to adhere to my demand so that the sound track level moves with with the sound track itself…
    I did try to replace the clip with black and it worked but there is no source on the sequence in the beginning just before the new 5 seconds of black I laid down as instructed by someone from the group suggested. When I try to remove the “blank space” (no audio/video) so the sequence starts with only 5 seconds of black the sound track I am concerned that the music under track moves with it but the levels stay in the same place so that the audio does not start where I had it before the move.
    I have tried to synchronize and un sync the track.
    I only want to remove the blank space and leave the rest of the seq. exactly where it is.
    I thought about copying the entire seq. to a new sequence without the blank tracks at the start of the piece but I have fubared the audio tracks as I did not understand the way PPro handled it when you dropped video on the timeline and I have 12 sound tracks. It seems that I can’t make them active unless I place a source clip in the source viewer and then it will only activate (assign a source tab that is active for the sound tracks that were associated with it in the beginning. I have some other source footage with mono tracks and the only way to activate them is by placing them in the source viewer and the associated sound tracks are active (A1, A2,etc.) Then the other tracks become inactive.
    Is there any way to copy the entire sequence from the “new inpoint” onto a new blank sequence?
    Is there a way to mark an Encore in point or start point so I can leave out the empty tracks that is my nemesis presently?
    Can I lock up everything and remove the blanks without moving the soundtrack levels?
    Any ideas would be appreciated. Can I do it in Encore? Like set the time in? Can I set the time in on the sequence and have it go to Encore? Can I shoot myself and end this dilemma?
    I started and stayed with Discreet Logics edit in 1997 and the user interface was much more intuitive, easy to work with and the documentation was much better. But that is ancient history and I am beginning to feel the same way.
    I went for PPro instead of FCP because of the uproar of it’s new release. I love the utility and scope of PPro but making it all work is a steeper learning curve than I ever thought it would be.
    PPro came with a video tutorial (from BH Photo)and it seems to fall short in a number of areas just as I do presently.
    Any links to address this stuff would be welcome.
    One final note. I just marked an in and out point on the sequence to copy it and possibly pasted it on a new sequence and all the tracks show as selected except the track that moves with out the levels!
    Any insight that will remedy this entire situation in any direction would be appreciated.
    I use Adobe Premiere Pro CS 5.5 on a IMAC 27, Intel core i5 2.7 GHz, 12 GB 1333 MHz DDR3… MAC OSX 10.6.8 I have a 2 Terabyte external drive fire wired in also.
    Thanks in advance for your help.
    Bruce
    Alex Udell replied 14 years, 7 months ago 3 Members · 5 Replies
  • Richard Knight
    February 20, 2012 at 7:51 pm
    Just start the work area bar 5 seconds before the start of the programme and this will be the start time for the export.
    Richard Knight
  • Bruce Klein
    February 20, 2012 at 11:04 pm
    Well I did just that. The bars/tone/countdown leader is gone but now It now has about 25 seconds of black before it rolls. I’ll give it another shot.
    I do thank you for your response.
    Bruce
  • Alex Udell
    February 21, 2012 at 10:19 am
    Hi Bruce…
    You likely did you mixing in track mode. That’s why the keyframes don’t ripple with the clips.
    there are a couple of ways to deal with this.
    option 1
    Sometimes a quick fix for this is to use nesting.
    1) Make a new blank sequence
    2) Then in the project panel drag your previously edited seqeunce onto the new sequence timeline.
    3) Now you can deal with it like a clip and trim it out to set up the the leader the way you want. The fully editable mix still exists within that sequence and will ripple accordingly as you trim and set up your leader.
    The downside to this is that you multi track mix will only be a stereo pair on this timeline.
    if that’s not acceptable then you will have try option 2
    forget the nesting and focus on your main sequence.
    You’ll have to use the Pen tool in the timeline and click and drag to marquee select all the keyframes in the track.
    This will turn them yellow.
    Then click on 1 of the hightlighted keyframes and start to drag left or right (earlier or later). There should be a time readout that tells you how far in time you are moving them.
    Also, if you then tap the SHIFT key during the drag, it should constrain the move (either horizontally or vertically depending on the way you are dragging at the time) this will allow you to move in time with out adjusting level by accident (or adjust level without shifting time by accident accordingly)
    You’ll have to repeat this for every track individually.
    Alex
  • Bruce Klein
    February 23, 2012 at 12:13 am
    Rich and Alex, I would like to thank you both for your suggestions and help.
    I just went back into the audio track and adjusted the levels. I am glad it was only one audio track.
    The question is if i were to adjust the levels with the mixer instead of key frames on the track would the levels move with the audio track?
    Also, I am still working on understanding the audio tracks and how they appear. Also how to toggle them off and on. I was having a miserable time getting tracks active or inactive. I found that I had to click back on a similar clip (the same type source clip) to make associated tracks active. I would then need to click back on the clip from another source to activate those associated audio tracks. I am referring to 2 different source files from 2 different cameras.
    With my old discreet logic’s edit, I could just “tab” a track and make it active or inactive and to copy was a cut/paste or drag and drop function.
    If you know of any links to tutorials concerning the sound tracks I would appreciate it.
    Bruce
  • Alex Udell
    February 23, 2012 at 11:00 pm
    Hi Bruce…
    Track level automation done by either the pen tool or the mixer, the result is the same. Keyframes on the track.
    However, there is an important distinction between clip keyframes and track keyframes.
    If you set your audio tracks to clip mode, and add key frames to the clips, then ripple edits and rearrangements will respect those keyframes and move with the clips. These keyframes can only be set with the pen tool in the timeline or in the effects controls panel for the individual clips
    If you set your tracks to track mode (which you were in) when you add keyframes, they are not associated with individual clips, but rather just a absolute position in time on a track and thus don’t move when you, ripple the events on the timeline.
    The same is true for audio effects (like reverb). they can be inserted and automated on clips or in the mixer bus at the track level. Effects and their automation applied at the clip level will follow the clip as you move/trim it.
    Why would you want to do this?
    It’s global versus local.
    Let say you get your cut in line and you want to start EQing, adjusting dynamics and wetness a particular talking head that you cut back to throughout a edit.
    If, after you edit, you isolate all the audio from that talking head down onto a particular track (a logical grouping if you will). Then you can apply the effects in the mixer and it will apply consistently to all clips on that track. Thus if you need to make changes, you make adjustments in one place. This is also important for wet/environmental effects, where, because the effects processing happens at the track level, reverbs will have natural decay, even if the edit event ends. If you apply reverbs at the clip level, the reverb will cut abruptly at the end of the edited event on the timeline.
    For levels editing, applying local keyframes at the clip level can help you smooth out jarring inconsistencies of peaks and valleys, but then you can make those now smoothed clips fit into the overall mix by adjusting at the mixer level.
    For music beds there may be specific passages that you want to control the level of. That may be better approached at the clip level. But if you are formatting a mix for a TV breaks in a show, you can add some automation at the track level. If the breaks need to happen at specified intervals, then you can replace the music clip, but the automation taking you in and out of a commercial break will still be in place.
    Hope this gives you some ideas as to how to approach audio in PPro.
    Alex Udell
    Editing, Motion Graphics, and Visual FX
