Activity › Forums › DaVinci Resolve › audio track goes silent
  • audio track goes silent
    Posted by Thomas Kaufman on August 15, 2021 at 12:52 pm
    I’m editing 2 audio tracks, I can see the waveforms of both but suddenly track one is completely silent. I checked in Fairlight and the edit page to see if track 1 was muted and it wasn’t. I feel like I’m doing something wrong but don’t know what it might be.
    thanks
    Thomas Kaufman replied 5 years, 1 month ago 2 Members · 2 Replies
  • Glenn Sakatch
    August 15, 2021 at 3:11 pm
    monitoring in Resolve can be a bit of a wormhole, so without screenshots of several other areas of the program, it is going to be hard to pin down the trouble.
    Some things to check.
    Are you clips panned left and right
    Are you hearing sound out of both speakers
    are you set for stereo monitoring, mono monitoring, 5.1 monitoring
    do you have audio busses set for something specific?
    If you drop audio on Ch1 down to 2, can you hear it?
    If you raise 2 up to 1, can you hear it?
    Are you sure both audio sources are still available to the program.
    You said at the start of your post “suddenly” does this mean at some point you could hear both tracks as they are currently laid out? If so, what did you change.
  • Thomas Kaufman
    August 16, 2021 at 6:19 pm
    Hi Glenn,
    Thanks so much for your email, I began going down the list of your suggestions when it occurred to me to try re-importing the audio clip. I did this and was able to proceed. I have no idea what I did to silence the track, but will try to find out in the days coming up.
    thanks again,
