Activity › Forums › Apple Final Cut Pro › Audio tools not showing for selected audio track
Posted by Jeff Leland on August 15, 2018 at 8:57 pmWhy are the regular audio tools not showing for certain tracks that I select? See example pics attached. Some show the tools – others do not. What am I missing here?
Tools are there on this one:
Tools are missing on this one:
The option to expand audio tracks is greyed out – audio is in stereo (but no way to change configuration?)
Anders Jørgensen replied 7 years, 10 months ago 3 Members · 8 Replies -
Anders Jørgensen
October 4, 2018 at 12:18 pmI had the same problem. My audio was set to “Dual mono”.
Changing it to stereo brought back the options you are looking for.Weird…
Anders
Anders Jørgesen
Photgrapher, editor, directorFeber Film
http://www.feberfilm.no -
Jeff Leland
October 4, 2018 at 7:10 pm -
Jeremy Garchow
October 4, 2018 at 7:47 pmYou can not add effects to a clip at the component level.
You have selected the clip in the Browser, then choose “Open Clip” which basically shows you all the components that a clip is made of. This isn’t good practice in FCPX.
You can put the clip on a timeline, and add effects there, but trying to add effects to the component level won’t work.
In my opinion there’s no reason to “open clip” to get to the clip components from the browser or timeline.
You can Expand audio components from the timeline (which is different form what you’re doing), that allows you to add effects to each component.
Jeremy
Jeff Leland
October 4, 2018 at 8:04 pmThanks Jeremy!
Bad technique. So if I open a project and drag the clip into it – everything should be there. What is a little baffling though is that the first time I encountered this I was already in a project working on a timeline – so not sure about why I was getting that error. Maybe I used “open clip” on that portion and then copied it into the timeline and that changed how that particular clip worked.
Anyway – thanks for that – I see now what that “open clip” is really doing…
Jeremy Garchow
October 4, 2018 at 8:07 pm[Jeff Leland] “Maybe I used “open clip” on that portion and then copied it into the timeline and that changed how that particular clip worked”
I’m not exactly sure and I am probably wrong about this, but at some point, FCPX changes that clip in to a synchronized clip in a Project, so maybe that’s what was happening.
Anders Jørgensen
October 8, 2018 at 9:59 amThe inspector tab – in the Audio configuration. Below your effect controls.
Anders Jørgesen
