Activity Forums Adobe Premiere Pro Audio too low after export
  • Audio too low after export
    Posted by Ahmed Sulaiman on March 13, 2016 at 4:18 pm
    Hi guys,
    I exported my project with these settings:
    Format: H.264
    Audio Codec: Dolby Digital
    Channels: 6
    Bitrate: 320
    Channel Configuration: 3/2 (L R C LFE Ls Rs)
    I checked the box that says (Enable LFE)
    After exporting my video, I noticed that the audio level of the exported file was too low compared to the original audio in my timeline. I played the exported video in VLC and the volumes were perfect just like the original project in premiere. but when I played the video in Quicktime player, the volumes were too low I almost couldn’t hear anything. I thought maybe the volume in VLC was set higher than %100 but it wasn’t.
    So I created another sequence in Premiere and I imported the exported video to the new sequence to check the audio meters and compare them with the original project, and I discovered that the volume of the exported video was in fact much lower than the original project.
    So the volume did decrease after the export. Any idea how I can fix this?
    Ayan Banerjee replied 9 years ago 5 Members · 7 Replies
  • 7 Replies
  • Mike Smith
    March 13, 2016 at 5:33 pm
    Quicktime player issue? Have you opened in PPro and checked the actual levels in the file that way? Or open in Audition, which will let you see what the audio level is in your file.
  • Ahmed Sulaiman
    March 14, 2016 at 6:42 am
    Yes I did. When I opened the exported project in Premiere Pro and Audition and checked the audio levels they were too low compared to the original file. The audio levels in my original project ranged between -20dB and -6dB, but after exporting the project and importing it in Premiere Pro and Audition, the audio levels are now ranging between -50dB and -30dB. Also When I play other videos in VLC & Quicktime player I can’t hear any difference in audio levels. It’s just my file that’s playing too low in Quicktime player but perfect in VLC.
  • Ahmed Sulaiman
    March 14, 2016 at 7:14 am
    Update: I exported my project choosing AAC as my Audio Format and it turned out perfect in both Quicktime player and VLC. Audio levels are the same as my original file.
    The problem only seems to happen when I choose Dolby Digital as the Audio Format. I still don’t know what’s causing audio levels to drop after export. It must be something in the Dolby Digital settings but I can’t figure it out yet. 🙁
  • Ahmed Sulaiman
    March 14, 2016 at 10:19 am
    Ok guys I managed to fix the problem by turning off “90º Phase Shift” option under the Pre-Processing tab when I chose Dolby Digital format. It was turned on by default. To be honest I don’t know exactly how this option was affecting my audio tracks when it was turned on, but turning it off brought the audio levels back to normal. I hope this helps someone in the future. 🙂
  • Chris Borjis
    March 14, 2016 at 5:56 pm
    one other thing that can make dolby audio quiet is if dialogue normalization
    is not set for -31
    apple compressor was notorious for this in it’s default configuration.
    (it would lower audio substantially)
  • Trig Simon
    March 19, 2016 at 3:06 am
    I thought that was what Ahmed did:
    “So I created another sequence in Premiere and I imported the exported video to the new
    discovered that the volume of the exported video was in fact much lower than the original project.”
    I found the same problem in exporting to DVD.
    Trig
    Trig Simon
    Video Images by Trig
    832 Main
    Toledo OH 43605
    419-693-0872
    http://www.videoimagesbytrig.com
  • Ayan Banerjee
    August 20, 2017 at 8:40 am
    This happened to me once. I was exporting uncompressed wav of a single track (I muted all the other tracks) , and the volume was very low when I put that exported audio clip back into the original track. But this did not happen when I exported all the tracks together as a single track and put it back on a single track in premiere. I have seen people posting this problem on the net. I figured out the problem so I would just explain it here.
    It was not a problem of premiere, but just my ow mistake. The single track I was exporting had an audio level set to (-10 db) in the audio mixer. Now I was expecting the exported clip to play at the same volume when I put it beside the original clip in the same track. But that should not be the case, since the original track is already lowered by -10db, it would additionally lower the volume of the new clip by 10 db again. So the exported clip will only sound the same as the original clip, only if we put the exported one, in a track with volume at 0db. (This is why the problem was not there when I exported all tracks together and put it in a new track with track volume 0db).
    So my suggestion is, if this happens to you, just check if the volume of the track you are exporting, is set at a lower decibel.
