Activity › Forums › Sony Cameras › Audio tips for the Sony NXCAM
  • Audio tips for the Sony NXCAM
    Posted by Preston Mullins on November 29, 2012 at 6:11 am
    I noticed that every time I barely bumped or even touched my Sony NXCAM, I could easily hear that touch or bump on XLR 2, where I have my shotgun mic plugged into. The internal mic is even worse at picking up these sounds. In a very quiet room, I could even hear the auto zoom mechanism, as well as turning the focus, zoom, and iris rings manually. I’m sure it’s do to the camera’s hollowness and plastic casing as is with other cameras.
    Anyway, I was playing with the ‘wind’ feature and to my surprise, it greatly reduced those problematic sounds I just mentioned. It went from bad to usable.
    Go to ‘menu,’ ‘audio set,’ ‘xlr set’ and from there you can turn the wind feature on or off for your choice of inputs. Turn it on, if it is not on already, to reduce those sounds. Of course it will also help reduce wind sound. I also changed the ‘trim’ on channel two to from 0 to -6db, which helped cut out white noise. Basically these settings will reduce low bassy sounds.
    Preston Mullins replied 13 years, 9 months ago 4 Members · 4 Replies
  • Eric Pensenstadler
    November 29, 2012 at 12:23 pm
    Very nice tip, thank you for sharing!
    Eric
  • John Lenihan
    November 29, 2012 at 2:32 pm
    Thanks for the tip. I would not have thought about using the wind noise button.
    Another thing I do in a very quiet room is to turn off the autogain, and just manually adjust the input level for the intended sound, which I presume is a person speaking.
    John
    John Lenihan
    LeniCam Video Productions
    https://www.lenicamvideoproductions.com
  • Michael Johnston
    December 14, 2012 at 7:53 am
    Preston, which camera are you using? I have none of those audio issues with the NX5 and that camera does not have a cheap plastic casing. It does pick up some zoom noise when speed zoom is turned on but Sony warns you about that in the user manual. As for the internal mic, it should only be used in emergency situations if your other mics die.
  • Preston Mullins
    December 19, 2012 at 5:46 pm
    Yes, I have the NX5U. I agree that the housing is not cheap plastic, which I never suggested it was “cheap.” And I never use the internal mic, I switched it over to test the noise issue I was having.
