Activity › Forums › Apple Final Cut Pro Legacy › Audio Timecode Reader Burn-in
Posted by Adrian Wibisono on December 7, 2009 at 9:28 pmIn final cut how do I have the audio time code (wav files) burn-in to the picture to lay to tape? FCS has a timecode filter for the video but not for audio. Is there any solution to this? thanks
Rafael Amador replied 16 years, 9 months ago 4 Members · 6 Replies -
Jerry Hofmann
December 7, 2009 at 10:31 pmDo you have Squeeze or Episode Pro? I’m pretty sure you can set the timecode to anything you want with their Window Burn filters…
Ive not tried it, but you might be able to put video whose opacity is zero, and set that video’s timecode to match the audio’s timecode in FCP…?
Jerry
Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things.
8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX Cinema Displays
Adrian Wibisono
December 7, 2009 at 10:45 pmWe do have squeeze or episode pro but I don’t think this approach is what we need. I’m trying to sync picture(mov) with the wav audio files. The client wants one of the copy with the audio timecode burn in to the picture.
Jerry Hofmann
December 7, 2009 at 11:05 pmSo… what you want is audio only with a black screen for the window burn?
Jerry
Adrian Wibisono
December 7, 2009 at 11:31 pmNo, i want picture and audio sync-ed, with the audio timecode burn in to the picture. I need to sync the picture and the wav files in FCS then lay it to tape.
Arnie Schlissel
December 8, 2009 at 1:11 amYou can use the time code generator filter to do this. Set the generator to start with the same TC number that the audio starts with, at the same rate, etc.
Arnie
Post production is not an afterthought!
https://www.arniepix.com/ -
Rafael Amador
December 8, 2009 at 2:39 amIt would work with the “TC Reader” filter IF FC would be able to pick the TC of the WAV file.
A the TC Reader/Generator are Video filters, I don’t see any easy way.
There is a way but this should be prepared before editing:
Making a QT movie with the audio and TC of your WAV in any codec with Alfa Channel. Make the picture fully transparent. You must edit so this transparent Video would go always to the top Video Track in the FC time-line. Then just drop the TC Reader filter in this transparent picture. You will get the TC of the WAV file and underneath the picture that you are editing.
It works.
Bouke Vahl (videotoolshed.com) may have something better.
Cheers,
rafael
