Activity Forums Apple Final Cut Pro Legacy Audio Time-Shift
  • Audio Time-Shift
    Posted by Tom Bell on June 8, 2009 at 2:07 pm
    Im not sure if this is in the correct forum… so apologies if not.
    Ive got an HD-CAM master running at 23.98 and a 5.1 surround audio supplied on a DA88 tape running at 25 (PAL).
    I need to capture the DA88 tape either at 23.98 (obviously the duration needs to stay the same) or convert from 25 to 23.98 after capture. Im wondering if there is a time-shift plug in in FCP or possibly Soundtrack?
    Tom.
    Michael Gissing replied 17 years, 3 months ago 3 Members · 2 Replies
  • Arnie Schlissel
    June 9, 2009 at 4:33 am
    In Soundtrack you can stretch (or in your case compress) the audio to fit the runtime without shifting its pitch. In FCP you can only do this by shifting its pitch.
    Arnie
    Post production is not an afterthought!
    https://www.arniepix.com/
  • Michael Gissing
    June 9, 2009 at 5:00 am
    I strongly recommend you take the tape to an audio post facility to get it into a file that can be run through either Pitch ‘N Time or MPEX3 software to stretch without changing pitch.
    If it is a long form show, the percentage is complicated, not a neat 4.1% but with lots of decimals or you will get drift. Time stretching without proper pitch correction will shift the audio 3/4 of a semitone flat. Not nice. Bad pitch correction sounds awful.
