Activity › Forums › Apple Final Cut Pro Legacy › Audio Tick on MP3 Import
Posted by Hopperhd on July 12, 2006 at 3:57 amHi all!
Quick question: I’m getting an audio tick, tick, tick while playing imported music into my timeline? The music sounds fine in iTunes but starts to subtlely…. tick, tick, tick… when playing along with my edited material?
Any ideas?
Thanks a ton!
JasonSebas replied 20 years, 2 months ago 5 Members · 5 Replies -
Shane Ross
July 12, 2006 at 3:58 amFCP needs AIFF files. MP3s don;t work.
#5 Imported music from CD or iTunes
Shane’s Stock Answer #5:
To get music into FCP, it needs to be an AIFF file at 48khz, 16 bit stereo. So if you want a song from a CD, you go into the iTunes Preferences and set this up under the IMPORTING tab:
File > preferences > importing > import using – AIFF encoder > Setting – Custom
Sample Rate – 48.000 kHz
Sample size – 16 bit
Channels – StereoIf you have an mp3 that you want to use, then you can convert it thru iTunes as well.
If the piece of music you want to use is something you purchased thru iTunes, I’m afraid I can’t help you there. There are copywrite issues that prevent files from being converted into the format that FCP can recognize.
Shane
Alokut Productions
http://www.lfhd.net -
Hopperhd
July 12, 2006 at 4:07 amThanks Shane! I didn’t purchase it from itunes so no foul there. I greatly apprecitae the ultra quick response. I must say, once again this site is a huge asset to us all!
Have a great night!
Jason
Tom Matthies
July 12, 2006 at 1:28 pmOr just use the tried ‘n true method of converting through Quicktime Pro. Just open the mp3 in QT Pro and export as an .aiff @ 48K. It will take you less than 30 seconds to do it this way.
Tom
