Activity › Forums › Broadcasting › Audio Tech Specs for Delivery of TV Spot
  • Audio Tech Specs for Delivery of TV Spot
    Posted by Sarah Johnson on June 30, 2013 at 4:36 pm
    Hi, I have a question regarding audio tech specs for delivery of a TV commercial. In the paperwork that I’ve been given, it lists a bunch of specs, most of which I’m used to seeing, except it says…
    Audio levels should peak no higher than -10dbFS
    Audio loudness levels should be -24 +/-2 per The CALM Act/ATSC A/85 specification
    Does this mean I should monitor my audio for -24db with peaks/spikes no higher than -10db?
    or
    Does this mean I should monitor at -10db?
    The audio is just a music track, so it’s pretty straight forward, no VO or SFX, etc.
    Thanks in advance for the advice, much appreciated!
    Sarah.
    Mark Spano replied 13 years, 2 months ago 2 Members · 1 Reply
  • Mark Spano
    July 2, 2013 at 4:43 pm
    ATSC A/85 is a guideline for using loudness measurement for audio as opposed to the traditional peak/RMS. The -24 +/- 2 number means that a loudness measurement of -24 LKFS should be the target. The peak level of -10 dBFs or -10 dBTP should be heeded as well.
    With a tool like Avid’s Pro Limiter, or the Waves WFM loudness meter (among many others), you can measure LKFS and dBTP easily.
    If you don’t have a loudness meter, you may want to look into a (somewhat) automated tool to gain change your mix into a loudness spec. Video Toolshed makes a very inexpensive tool where you feed in your mix file, set the specs, and it outputs an adjusted file to match the spec.
