Activity Forums Adobe Premiere Pro Audio targeting in Multi Camera edits Premiere 5.5
  • Audio targeting in Multi Camera edits Premiere 5.5
    Posted by Mark E. roberts on August 16, 2012 at 2:04 am
    I am editing 6 days worth of multi camera shots from a seminar I shot last month. I am using Premiere Pro 5.5.
    I shot the class with the speaker mic’ed with 2 wireless lapel mics: one mic going into cam 3 left channel, and one going into cam 2 right channel; the open channel on each camera catching ambient audio via camera mics. The thought here was I would have some redundancy in the event one mic popped out due to battery issues, or interference, and still have an audio channel to sync to with PluralEyes.
    Camera 1 was a wide shot of the front of room, and had 4 choir mics directed at the audience (to pick up questions and such) running into a mixer, and then into cam 1.
    In Premiere, I line up all the video shots with PluralEyes (or manually) and then nest that sequence into a new multi cam sequence and begin editing.
    My issue is how to get the cleaner audio of the instructor, which is on either CAM 2 or 3 (with the lapel mics), onto the track of CAM 1, which is the only track I am able to hear when doing multi cam edits.
    I have worked around this by copying the audio from track 2 or 3 onto track 1 in the original (not nested) sequence and that has worked and I could keep on editing. But now, I need to do a group discussion portion, and need the audio from track 1 as well as the others and I am not sure how to mix them into the main audio track that the multicam process requires.
    I hope I am clear in my explanation. In essence, how do you get a mix of tracks to show up onto track 1, the only audio track that seems to be able to be read by the multicam feature in Premiere 5.5?
    Many thanks!!
    Mark
    Mark E. roberts replied 14 years ago 1 Member · 0 Replies
  • 0 Replies
