Activity › Forums › Adobe Premiere Pro › Audio Syncing problem
  • Audio Syncing problem
    Posted by Anna Heuss on March 24, 2014 at 12:35 pm
    Hi, I’ve searched the web but found no solution, so hope someone here can help me. I am also not used to working in Premiere so maybe it’s just a simple step I’m missing here.
    So I have some footage with in-camera sound on the first 2 tracks. There are 8 tracks in total, but I only want to use 1&2 as backup and reference for syncing my clips with the externally recorded audio.
    For some crazy reason the sound recordist decided to record only 1 (!) audio file per shooting day. So although I have 100 video clips all nicely named and with a wonderful clap at the beginning of each clip, I only have one sound file for these 100 clips. I thought the best way to sync would be to place the audio file on the timeline, add my video files with track 1&2 (throw tracks 3-8 away) as reference, align them to sync, cut off the bits of audio I dont need, make a new independent clip or subclip or whatever and then use that for editing. (I could just sync using in-points with each new clap, but I dont want to drag 10 hours of audio around in each merged clip…how annoying).
    BUT!!! When I’ve done that and open my new clip in the viewer, then edit a part of it into the timeline….it’s like it just added 20 extra audio tracks for no reason. I should have 4 audio tracks – the external audio and the 2 in-camera tracks. Why do I get 20 tracks? And I can’t deselect them either…it just wants to use all these millions of tracks…I dont understand. What am I doing wrong?
    In FCP there was a “make independent clip” option which would…well…do exactly that, make a new clip with just the audio you had added.
    Any feedback highly appreciated – or better ways of syncing audio in Premiere. Thanks
    PS. I forgot to mention that the externally recorded audio is stereo, not mono, in case that makes a difference.
    Tim Kolb replied 12 years, 6 months ago 2 Members · 6 Replies
  • Tim Kolb
    March 24, 2014 at 12:49 pm
    What version are you using?
    TimK,
    Director, Consultant
    Kolb Productions,
    Adobe Certified Instructor
  • Anna Heuss
    March 24, 2014 at 1:15 pm
    Premiere Pro CC
  • Anna Heuss
    March 24, 2014 at 1:18 pm
    7.0. sorry
  • Tim Kolb
    March 24, 2014 at 1:55 pm
    It’s not CC?
    Where are you seeing the version?
    TimK,
    Kolb Productions,
  • Anna Heuss
    March 24, 2014 at 2:05 pm
    It says here Adobe Premiere Pro CC v7.0
  • Tim Kolb
    March 24, 2014 at 7:36 pm
    OK…You may want to update the application as I think 7.2.1 is current.
    On the issue at hand, I might suggest taking the carefully structured video clips and place each on a timeline, sync the appropriate external audio, mute (or delete) the tracks you don’t want…then lock the racks and use each sequence like a source clip…a -nested sequence- in Adobe terminology.
    TimK,
    Kolb Productions,
