Activity Forums Adobe After Effects Audio Synchro in CS3. “Audio Hardware settings”
  • Audio Synchro in CS3. “Audio Hardware settings”
    Posted by Juanantonio Domingo on November 21, 2007 at 3:49 pm
    Greetings!
    I’ve been very very distressed these days. I’ve had a lot of problems with CS3 with audio Synchro. The same video with CS2 plays audio and video perfectly: RAM preview and export movie.
    I’ve discovered the new preference called “Audio Hardware”. As far I know this function is implemented to take full advantage of the sound card installed in the computer. After one thousand changes I’ve discovered, at least in my computer, Core Duo 2gigs of RAM, RAID 0 for video, etc that there’s a value in this setting “Buffer Size [samples]” that should be at its minimum value 512, the more you enter the more is out of Synchro.
    I hope if someone suffers this situation could find in these settings the right solution for Audio Synchro.
    Thanks.
    Juanantonio Domingo replied 18 years, 10 months ago 1 Member · 0 Replies
  • 0 Replies
