  • Posted by Robert Elliott on May 11, 2005 at 6:58 pm
    Hi All,
    I’m trying to play back an AIFF file in the viewer window and playback is not synching with the waveform of the file. I’m playing the file out through built in audio. I’m playing it in Final Cut HD 4.5. The file is a 48000 Hz 16 bit file approximatly 13 seconds. If I move to different sections of the file and try to play it back sometimes I won’t hear audio where the waveform indicates there should be audio. Does anyone have any suggestions?
    Rob
    Robert Elliott replied 21 years, 4 months ago 1 Member · 0 Replies
  • 0 Replies
