Activity Forums Adobe Encore DVD Audio sync slipping on long blu-ray
  • Audio sync slipping on long blu-ray
    Posted by Terry Flaxton on July 5, 2011 at 7:19 am
    We’re compiling a blu ray with 6 hours 10 minutes of HDV originated footage.
    Output as pro-res, transcoded in Compressor, assembled on Encore, put on a 50 gig dual layer.
    Though all the interview clips are discrete, from clips 11 through to 17 the audio slips at an inconstant rate (though it’s hard to tell – it might be 2 or 4 frames, or even 6 occasionally). Staring so long at it we might even be talking ourselves into thinking it’s slipping between sync and out of sync.
    We’ve thought of a million reasons, read the list, searched google. Is the problem that there’s too much data, the pathway we’ve chosen, the actual form we’re using – or is there a fix?
    A long term DP – likes 35mm and HD equally – changing with digital media – Began as a commercials editor !
    Terry Flaxton replied 15 years, 2 months ago 2 Members · 2 Replies
  • Daniel Ludwig
    July 5, 2011 at 8:18 am
    hi terry,
    there should be no reason why your audio getting out of sync.
    could you please give us a bit more details about the project.? is it a single film of 6h10, or are there seperated clips.
    which video-and audio-codec did you use? MPEG2, H264, PCM or AC-3?
    have you checked the original file if it is in sync?
    cheers
    danny
  • Terry Flaxton
    July 18, 2011 at 1:57 pm
    Thanks for this and whilst I went offline.
    I discovered the people supplying the streams were giving one extra frame of audio per interview which was the cause…
    doh!
    Best, Terry
