Activity Forums Panasonic Cameras audio sync problems when capturing to FCP at 23.98 from 1200a
  • audio sync problems when capturing to FCP at 23.98 from 1200a
    Posted by Gewan Brown on July 21, 2006 at 1:33 am
    We have Varicam H footage shot at 24p (with system frequency at 59.94), so 23.98 footage. We are playing off a 1200a deck into a decklink card (HD Pro Dual Link) to capture into FCP(5.0.1). If the easy setup is set to DVCPro HD 59.94, then everything is dandy, audio syncs up. But then I can’t get the Frame Rate Converter software (v 1.0) to work (error = can’t conform source media).
    When I try capturing at 23.98, video is fine, no redundant frames etc, but the audio is out of sync by 3 frames.
    Any suggestions? Is capturing off the 1200a at 23.98 supported? What gives with the FRC not working? What preferences if any should I try clearing?
    Where does the FRC app install to… FCP package contents show no sign as far as I can tell.
    Thanks in advanced!
    G1
    Gewan Brown replied 20 years, 1 month ago 4 Members · 5 Replies
  • Chris Bell
    July 21, 2006 at 4:40 am
  • Gewan Brown
    July 21, 2006 at 6:08 am
    Nice tutorial but not really relevant.
    My footage was shot at 24p on a Varicam and I want it 24p on the timeline. So you’d think that a straight captire would work, and the video does, but the audio is out of sync. The FRC is a seperate issue that I simply brought up to let readers know I’m at a loss with the option of capturing at 59.94 and removing flagged/duplicate frames. The 59.94 captures are in sync.
    So shouldn’t a straght 24p capture work with no audio problems? Or does everyone always go 60p?
    Could there be a setting issue on the 1200a for output????
    Last I checked it was set to 720p format, 59/60 frequency. If I put it in 23/24 frequency it acts weird (goes off the monitor).
  • Noah Kadner
    July 21, 2006 at 3:01 pm
    This refers to a different 24p camera but the process you need to comprehend is the same:
    https://www.larryjordan.biz/articles/lj_dvx_capture.html
    Noah
  • Gary Adcock
    July 21, 2006 at 7:31 pm
    [gewanbrown] “My footage was shot at 24p on a Varicam and I want it 24p on the timeline. So you’d think that a straight captire would work, and the video does, but the audio is out of sync.”
    The audio capture is 2 frames out of sync with Varicam F and earlier models and traditionaly 3 frames with HDCam.
    It takes a lot more processing for video than it does audio. hence the delay- The H model Varicam can compensate for the delay but do not use it if you are shooting multicamera for the obvious reasons.
    gary adcock
    Studio37
    HD & Film Consultation
    Post and Production Workflows
    Chicago, IL
  • Gewan Brown
    July 23, 2006 at 7:05 pm
    Wow! So it is actually know issue? Well that doesn’t make me feel any better but it makes my workarounds appropriate I guess. I’ve been capturing all audio critical footage in long streams, offsetting the audio and then reimporting and making sub-clips.
    Is there another workaround that has become the “standard”???
    Gewan
