Audio sync problems on FCP in NTSC project
Hello everyone
My name’s Vladimir, I’m an editor and I work in Moscow
I started working on a big project that was shot in US on a betacam SP camera in NTSC. I have FCP on G5 Quad equipped with Kona LH card, that supports NTSC and PAL with equal success (I might be wrong please correctme if I really am). The footage was captured from Sony J-30 player, which supports NTSC as well, via SDI output with embedded audio. The clips look OK, but when I play them back from viewer or sequence have audio out of sync, it drops and then completely shuts after 7-8 seconds after start. I can’t put my finger on the problem I may have, so I’ll appreciate any advice on that. Thank you in advance.
