Activity Forums Adobe Premiere Pro Audio sync problems at end of clip
  • Audio sync problems at end of clip
    Posted by Kendall Shaw on February 21, 2015 at 3:57 pm
    Nearly always the rendered result of a clip in any program I have used with multiple type of source and audio footage and multiple combinations of compression, has either the audio truncated before the video ends or the audio is out of sync at the end.
    I “solve” this while working on a project by appending filler to a clip so that the audio and video are in sync and complete up to the point where the filler starts.
    Whenever I have posed this question in the past, people want an example then the discussion quickly goes off on a tangent and I have never read any illuminating comment on the subject.
    Unless I am the only person that has this happen, can someone offer an explanation that is general, applying to multiple scenarios, so that I can use the explanation to address the problem when it occurs in the future
    Sibel Zivy replied 11 years, 6 months ago 2 Members · 2 Replies
  • Sibel Zivy
    February 24, 2015 at 8:40 pm
    I’m fairly new to Premiere Pro, I use cc and I’ve been facing the same issue for the past 3 months, could you show how you mended this, Thank You.
    I’ve seen your previous posts, but I didn’t find the answers helpful.
  • Sibel Zivy
    February 24, 2015 at 8:59 pm
    Please post the solution once you find it, Thank you!
