Activity Forums Apple Final Cut Pro Legacy Audio sync problems
  • Audio sync problems
    Posted by Lachlan Fletcher on November 20, 2011 at 8:22 am
    Hey all. I have an issue that i have seen come up a lot but I haven’t found it resolved. I have a project that has pro res LT vision with audio recorded at 48KHz at 16 bit. I am syncing it with .wavs recorded at the same KHz & bit rate as I do on a daily basis. The problem is that this time the timeline runs out of sync & I cannot figure out why. All the settins seem fine ie 48 bla bla….
    Any ideas??
    Lach
    Lachlan Fletcher replied 14 years, 10 months ago 3 Members · 3 Replies
  • Jerry Hofmann
    November 20, 2011 at 2:54 pm
    Try transcoding the WAV’s to Aiffs, then syncing.
    Jerry
    Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: https://blogs.creativecow.net/Jerry-Hofmann
    Current DVD:
    https://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX – Cinema Displays I have a 22″ that I paid 4k for still working. G4 with Kona SD card, and SCSI card.
  • Michael Gissing
    November 20, 2011 at 9:14 pm
    And read this tutorial, particularly the second half that tells about the correct importing of audio assets so FCP can frame rate stamp the audio correctly. This is such a common problem that this question pops up a few times each week –
    https://library.creativecow.net/lyon_matt/fixing-fcp-assets/1
  • Lachlan Fletcher
    November 21, 2011 at 1:10 pm
    Hey Jerry,
    Thanks for the reply. Your right that works I tried it last night as a last resort before I received your post.Im unsure why as 99 times out of 100 its fine but hey….. whatever works!!
    Thanks mate
    Lach
