Audio Sync Problem w/ Varicam H and Ki Pro Mini
I’ve been doing some tests with Ki Pro Mini and a Varicam H. The recorded audio is 2-3 frames ahead of video. I updated to the latest 2.1 firmware this afternoon and still experiencing the audio/video sync issues. This is happening on both 30p and 24p.
I also get a “false recording” @ 30p in the VFR setting: I see a freeze frame of video while hearing the recorded audio. I have to use NORMAL or PsF setting to get 30p video recorded. 24p works properly in VFR. Regardless, the sync issues are apparent in any combination of settings.
FYI, I am using a AJA “approved” CF card (SanDisk Extreme Pro 32GB @90MB/s).
I spoke on 2 occasions with AJA Tech support. I updated Firmare at their recommendation but this didn’t resolve the issue.
