Activity › Forums › Adobe Premiere Pro › audio sync problem – it can’t be this hard
Posted by Brett Nelson on January 30, 2006 at 2:50 pmI’m trying to figure out what I’m missing. I’m capturing a two camera interview shot on miniDV. I capture the whole tapes in PPro 1.5. I put them on the timeline and they drift out of sync. The project settings are 48k and the tapes were captured as standard DV in. They are in sync when I view them outside of PPro (Vegas).
I’ve searched FAQs and can’t find an answer. This should be such a no-brainer, it’s driving me completely crazy. Thanks!
Brett Nelson
Brett Nelson replied 20 years, 7 months ago 6 Members · 13 Replies -
Tim Kolb
January 30, 2006 at 4:26 pmDo you mean the shots are out of sync with each other, or that the audio in one/both of the shots goes out of sync with the video?
TimK,
Kolb Productions,
Creative Cow Host,
Author/Trainer
http://www.focalpress.com
http://www.classondemand.net -
Brett Nelson
January 30, 2006 at 4:49 pmSorry to be unclear. The audio goes out of sync with its own video. It starts in sync at the head and ends up several seconds out of sync by the end of the hour. I’m not worried about matching the shots as long as each camera is holding sync.
Brett
Tim Kolb
January 30, 2006 at 4:59 pmWhat camcorder is the audio from?
Was the audio in “locked” mode?
TimK,
Kolb Productions,
Creative Cow Host,
Author/Trainer
R. Hewitt
January 30, 2006 at 6:25 pmAre you using a hardware accelerator such as the Matrox RTX10 or 100?
Brett Nelson
January 30, 2006 at 6:39 pmNo. Does this sound like it could be fragmentation? I am running with a 300GB drive…actually 2 ATA IDE 7200 drives that are striped. There is only 20% free space. I am doing a defragment now, but of course it’s very slow with such a big drive.
I’m running this on a dual 2.4gHz Supermicro with 1GB of RAM…PPro 1.5, WinXP Pro SP2.
Brett
Brett Nelson
January 30, 2006 at 7:06 pmWell, defrag isn’t it, or at least isn’t all of it. I did a defrag and have the same problem with no change. I’ve tried the same clip running on an external Firewire drive, tried creating a 48k and 44.1k AIF and using those instead, and I tried importing the clip into a 44.1 project…all with no luck.
Brett
Dave Baldwin
January 30, 2006 at 8:06 pmHave you deleted the conformed audio files? If not, I would try that to see if Prem rewrites them with better results.
Good Luck.
db
Brett Nelson
January 30, 2006 at 8:45 pmThanks, but still no. It’s strange because I have about 14 hours of footage in another project all captured as hour-long clips and they play fine. I tried importing one of out-of-sync clips into that project and dropping it into one of those sequences. That didn’t do it.
Brett
Mike Velte
January 31, 2006 at 12:25 pmDropping video frames during capture can cause the audio to drop behind the video. Try recapturing and note at the top of the capture window if any frames where dropped.
