Audio sync problem in FCP (Sub-frame editing required) one frame accuracy just not good enough!
I’m hoping an FCP genius out there can help me with a sync issue that is driving me insane!
I’ve worked in broadcast TV for over 20 years but filmed a concert (last minute) with two DSLR’s.
The main camera (close-ups) were shot at 1080p (24fps) and the other camera (wide) at 720p (29.97fps).
I have been given the master audio files [44.1khz rate] (from desk) which sound amazing, and I’ve set up timeline sequence at 720p with 44.1 and 24fps. Why is it that on each individual song, there has been a slip (cumulative) so that it starts off in sync and then ends up half a frame out by the end of the song, (say around 4 minutes). I’ve just been given a new version of the full concert as one whole file, so I’m going to start from scratch. With the violinist and guitarist playing quite fast in places, one frame accuracy is simply not good enough. Can anyone shed light on this mystery and offer a better workflow solution? It took me around two weeks to cut the first version, so I’m assuming it will take that again to re-cut the new version. Why is it that FCP7 cannot perform sub-frame editing of the audio on the timeline??? You can only do it in the preview window and then the scrub-bar is not accurate (it’s too fat in width!!!) enough to perform the task by sight on the waveforms!!! Arrrrghhhh!!! Does anybody have any thoughts on this issue?
Does Avid allow for more accurate sub-frame editing?
When a band plays at over 100bpm, one frame accuracy simply is not good enough.
