Activity › Forums › Apple Final Cut Pro Legacy › Audio Sync Issues with OMF
Posted by Andy Lancaster on April 17, 2009 at 7:10 pmHas anyone had audio sync issues when exporting an OMF to be mixed in Pro Tools? It doesn’t happen with any project and usually only effects one track.
Michael Gissing replied 17 years, 4 months ago 4 Members · 3 Replies -
Shane Ross
April 17, 2009 at 8:32 pmNope. Are you working on a 23.98 timebase and they import into a 29.97 timebase or anything like that?
Shane
Read my blog, Little Frog in High Def -
Chris Borjis
April 17, 2009 at 8:39 pmalso check drop frame / non drop in pro tools.
one thing that will help you avoid this forever is to create
a DV-NTSC quicktime .mov file with timecode burned into it.when loaded into protools they can go right to the beginning
and end and verify with the protools timecode that there
will be no synch drift.I’ve done countless 23.98 and 29.97 omf exports for my
audio engineer and they are always in synch. -
Michael Gissing
April 17, 2009 at 10:44 pmThe last time I had one track sync issues with FCP was version 2. Not had a sync issue since version 3 FCP. I don’t use ProTools however.
In the old days, dissolves used to push clips out of sync by the length of the dissolve. To find the problem the old trick was to line up a pip at the start and end of a sequence on every track. That made it easy to work out if a track had pushed.
