Activity Forums Panasonic Cameras Audio Sync Issues with DVCPRO HD footage and a AJ1200 Deck
  • Audio Sync Issues with DVCPRO HD footage and a AJ1200 Deck
    Posted by Editlord 5000 on November 22, 2006 at 11:27 pm
    I am having seemingly random clips that I have captured in FCP 5.1 be out of Sync. The Audio is playing before the footage on my capture scratch as well as in FCP. Most of the clips are fine but every once in while I will get one bad one. Is there a possible setting on the deck or in FCP that would make this Happen, or is this just a freak occurance? SAM
    Shane Ross replied 19 years, 9 months ago 2 Members · 1 Reply
  • Shane Ross
    November 25, 2006 at 6:14 am
    This happens to me all the time….EVERY clip. Typically the offset is two frames. Audio hits two frames before video. But sometimes it is 8 frames and that is REALLY annoying. And I’ll capture the footage again and again and by logging and capturing, or by Capture Now…and I get the same result for the clips…either 2 or 8 frames.
    So I adjust the footage on the timeline as I edit. Cut it in, slip the audio. I’d like to avoid that, if I could, but I haven’t found a solution to this dilemma yet.
    Sorry, just comiserating (sp?)
    Shane
    Littlefrog Post
    http://www.lfhd.net
