Activity › Forums › Apple Final Cut Pro Legacy › Audio Sync issues
Audio Sync issues
Posted by Eric N on March 3, 2006 at 4:42 pmHi, My audio is out of sync and I don
Eric N replied 20 years, 6 months ago 3 Members · 6 Replies -
Bouncing Account needs new email address
March 4, 2006 at 5:16 amHow are you monitoring FCP’s audio output?
Eric N
March 6, 2006 at 5:59 amI just monitor my audio through the computer. But the audio sync problem occurs on more than one computer that I use. I know that its final cut because if I watch the tapes through my deck on TV, they work fine.
Thanks for your help,
Eric -
Eric N
March 6, 2006 at 6:01 amIm just using internal drives in my tower, so no fire wire or anything like that.
Eric -
Debe
March 6, 2006 at 2:18 pmWell, there you go.
Final Cut is designed to be used in conjunction with external video and audio monitors.
Check the manual for proper set up using external audio and video monitors. It’s likely the problem will go away after you connect external monitors correctly.
debe
