Activity Forums DaVinci Resolve Audio Sync Issues
  • Audio Sync Issues
    Posted by Perry Trest on December 15, 2014 at 3:41 am
    I’ve read several posts here on audio sync with various hardware configurations but can’t seem to figure out what is going on with my particular setup.
    I have a FSI CM170 in the edit bay connected via HD-SDI as well as a Panasonic plasma connected via HDMI.
    My dual boot system includes Avid Media Composer with Nitris DX on one partition and Adobe Premiere Pro/Davinci Resolve with BM DeckLink SDI on the other partition.
    My issue is this:
    When working on the Avid partition (Nitris DX), picture and sound are in sync on the Panasonic but out of sync on the FSI.
    When working on the Adobe/Davinci partition (DeckLink SDI), picture and sound are in sync on both the Panny and FSI regardless of which software I am working with.
    Can anyone explain why the audio and video arrive in sync on both monitors with Adobe/Davinci/DeckLink but not with Media Composer/Nitris DX?
    Thanks in advance.
    Perry Trest
    POSTDIGITAL, Inc.
    http://www.perrytrest.com
    OS 10.9.4
    Davinci Resolve 11.1 Licensed
    MacPro 12core 3.33Ghz (2010)
    32GB RAM
    Slot 1 = GTX780 6GB GUI
    Slot 2 = Cubix Xpander
    Slot 3 = DeckLink SDI
    Slot 4 = Nitris DX
    Cubix Xpander = GTX780 6GB GPU + Caldigit eSata/USB3
    Internal 6TB soft RAID-0
    Euphonix Artist Color
    Flanders Scientific CM170
    Davinci Resolve 11 Lite
    iMac 27″ 2.7GHz Quadcore i5
    20GB RAM
    Blackmagic Mini Monitor
    Glenn Sakatch replied 11 years, 9 months ago 3 Members · 4 Replies
  • Joseph Owens
    December 15, 2014 at 5:33 pm
    [Perry Trest] “Can anyone explain why the audio and video arrive in sync on both monitors with Adobe/Davinci/DeckLink but not with Media Composer/Nitris DX?”
    Is there a latency offset (#of frames) in the Media Composer output configuration? In Final Cut Pro, the default offset is 4 frames, which you have to set to either 0 or 1 depending on your master monitor’s latency.
    jPo
    “I always pass on free advice — its never of any use to me” Oscar Wilde.
  • Perry Trest
    December 15, 2014 at 5:59 pm
    Thank you for the input.
    I’m thinking the latency offset in software is to sync the GUI to the external video monitor.
    I am wrong about that?
    I’m not concerned about the computer monitor and video monitor syncing.
    I monitor sync on the external video monitors.
    It’s that I have two external monitors and when using Media Composer the HDMI feed from Nitris is in sync but the SDI to FSI is out of sync.
    The odd thing is that when I’m using Davinci or Premiere, both video monitors are in sync.
    Perry Trest
    POSTDIGITAL, Inc.
    OS 10.9.4
    32GB RAM
    Slot 4 = Nitris DX
    20GB RAM
  • Joseph Owens
    December 16, 2014 at 5:38 pm
    [Perry Trest] “the SDI to FSI is out of sync.”
    If it is late from the Decklink via SDI, then that sort of points to a software-related latency in handing off the picture to the PCIe card. Resolve (and can’t comment on Premiere) has no such adjustment, and really, the latency should be zero. I used to have to reset this in FCP every time there was a point version release in either Desktop video, AJA Control Panel, or Final Cut itself, because those 4 frames would be re-established.
    jPo
  • Glenn Sakatch
    December 17, 2014 at 2:24 pm
    Sounds like an Avid issue then. If Resolve and premiere are always in sync. I don’t use a Nitris box, but maybe it isn’t capable of handling both outputs at once? Have you tried only 1 output to see it that is in sync? (either sdi or hdmi?)
    Might be worth a post on the Avid forum.
    Glenn
