[mynor rodriguez] “I have not transcoded them because i don’t know what that is quite frankly, just AMAing them.”
OK…I don’t want to sound snarky here, but that is something that you should know about. Before you begin editing, it is wise to know how your edit system works. What the proper workflows are for bringing in footage. Transcoding is a very basic function, and one vital to editing successfully in Avid Media Composer.
AMA is Avid Media ACCESS. This is Avid’s way of interfacing with tapeless media. But one should not edit footage that has only been AMA’d. Avid craves Avid media, and Avid media structure (organization) in order to work properly. This means that you need to consolidate (if the media is a format Avid works with natively, like HDV, XDCAM, P2), or transcode to Avid media (DNxHD) if it is a format like AVCHD, H.264, AVCHD…and so on. Avid’s world class media management only works if the media is in the proper file structure…Media hard drive>Avid MediaFiles>MXF>1…2… and so on.
Avid is NOT designed to work with most media formats natively, via AMA. Marketing might say this, but reality is different. If you want to work with media natively, you need to look at Adobe Premiere…and get a machine with fast processors, lots of RAM, and a good graphics card that enables the Mercury Engine.
[mynor rodriguez] “Do you believe transcoding them will do the trick?”
Yes, because that’s how Avid is designed to work.
[mynor rodriguez] “Might there be too much data at one time?”
No. Media not in the Avid media format, or the Avid media structure, can cause issues like sluggishness and sync loss.
Shane
Little Frog Post
