Activity › Forums › Apple Final Cut Pro Legacy › Audio Sync Issue- Any advice?
  • Audio Sync Issue- Any advice?
    Posted by Ben Lithman on March 22, 2011 at 4:05 pm
    I have an FCP project where the audio appears to be out of sync by a few seconds. I’ve tried deleting the footage from FCP and bringing it back in from the capture scratch, but always get the same result.
    What is really odd, is that when I play the video in Quicktime X or Quicktime 7, the audio is in perfect sync. The issue only seams present when in FCP…
    Can anyone help??
    BTW It’s DV PAL footage…
    Jerry Hofmann replied 15 years, 6 months ago 2 Members · 1 Reply
  • Jerry Hofmann
    March 22, 2011 at 7:10 pm
    Check the kHz of the recording itself. The camera or deck will report the bit depth. If it’s reported as 12 bit (usually in the viewfinder or on screen display), capture at 32kHz, 16 bit, not 48… if it’s 16 bit then it’s 48kHz…
    Jerry
    Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: https://blogs.creativecow.net/Jerry-Hofmann
    Current DVD:
    https://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX – Cinema Displays I have a 22″ that I paid 4k for still working. G4 with Kona SD card, and SCSI card.
