Activity › Forums › Apple Final Cut Pro Legacy › Audio sync
Audio sync
Posted by Eric N on March 2, 2006 at 8:58 pmHi, My audio is out of sync and I don
Tom Meegan replied 20 years, 6 months ago 2 Members · 3 Replies -
Tom Meegan
March 8, 2006 at 2:04 pmHi Erik,
If you get an out of sync message on the time line, Right-Click (or Control-Click) on the red marker and choose the appropriate solution. If you are not sure, experiment. If you don’t like what you see, Command-Z to undo.
Is your video out of sync with the video even when it is not reportedly out of sync in the time line? How are you viewing your video and listening to you audio? Where is your footage acquired from? I’m not sure that I know what fs48K is.
Sorry about all the questions
Eric N
March 8, 2006 at 5:05 pmIve gotten the message before but I never saw a red marker, what do you mean exactly? If by red marker you mean the
Tom Meegan
March 13, 2006 at 3:09 amIt is likely that you are dealing with “unlocked audio.” If my answer below rings true at all, you should read this link for a deeper understanding of what might be going on.
https://www.adamwilt.com/DV-FAQ-tech.html#LockedAudio
It sounds like the tapes in question were shot with an inexpensive camera, and that the audio rate might be a bit different (unlocked.) Right click on the clip in the browser and go to Item Properties > Format. Aud Rate should be 48.0 KHz. I’m going to guess it is close but not quite
