  • Posted by Tony Luke on May 24, 2007 at 5:43 am
    Hey, I saw someone else was having a similar problem here, but mine is just a bit different. I capture the footage at the right settings, and somewhere closer to the end of the footage (about 3/4) the audio suddenly goes out of sync. Does anyone have any idea as to why this happens? Is it because I’m not breaking up the capturing into smaller segments (some go as long as 20 or so minutes straight)
    Thanks so much!
    Tom Wolsky replied 19 years, 3 months ago 2 Members · 1 Reply
  • Tom Wolsky
    May 24, 2007 at 12:18 pm
    Without being giving full specs on your system, what you’re doing, and what settings you’re using, it’s pretty much a guess. The most common cause is capturing material with the wrong capture settings for your media.
    All the best,
    Tom
    Author: “Final Cut Pro 5 Editing Essentials” and “Final Cut Express 2 Editing Workshop” Class on Demand “Complete Training for FCP5” and “Final Cut Express Made Easy” DVDs
