Activity › Forums › DVD Authoring › audio surf to call a subtitle stream
  • audio surf to call a subtitle stream
    Posted by Dimitrios on June 20, 2006 at 4:59 pm
    Hello everyone,
    I got a question regarding switching between streams. Can you advice if there is a way to turn a stream on (lets say subtitles) by surfing between the audio streams using the remote control. I know I can do it if I call a stream from a menu and set commands to activate another stream, but what I really want is to be able to have subtitles on, when I use the remote control to switch to another audio stream while the current is playing…
    Any ideas would be very much appreciated.
    D
    Dimitrios replied 20 years, 3 months ago 1 Member · 0 Replies
  • 0 Replies
