Activity Forums Adobe Premiere Pro Audio stutters & jumps
  • Audio stutters & jumps
    Posted by Greg Beckt on July 2, 2006 at 5:17 pm
    I’m using 2.0 for the first time and my audio is extremely erratic/glitchy. Even with one track of music or voice, there’s stuttering…never had this problem in 1.5, even with multiple tracks and multiple f/x. Let me know if you have any suggestions for troubleshooting. Here’s some steps I’ve taken so far to try and isolate…
    -The problem isn’t file specific(happens with different sources, whether 48kHz or 41)
    -I don’t believe it’s scratch disk based…I have a Raid0 and an internal SCSI, and have tried various configs for original media, previews, etc.
    -Updated my soundcard driver, although this is just an OEM SoundMAX.
    -Tried all three of the combinations of Audio Hardware settings within PPro(Pro, Default, 1.5, etc).
    -PPro 1.5 still works fine
    -This is a CineformHDV project, but the same problem exists for normal SD DV projects.
    -Not running multiple applications simultaneously
    I recently did the SP2 upgrade…wondering if there’s some system settings that need to be changed that are PPro 2.0 specific??
    I’ve done a search here, at Adobe’s site, and at Cineform without much luck…let me know if you have any suggestions…thanks!
    Greg
    HP xw6000
    Dual 2.8 Xeon
    3GB Ram
    Production Studio
    Greg Beckt replied 20 years, 2 months ago 2 Members · 2 Replies
  • Vince Becquiot
    July 2, 2006 at 6:01 pm
    Greg,
    After all this, it may be worth trying a clean install of Premiere, if you haven’t done so yet, even deleting preferences may help.
    Is 1.5 installed on the same machine ?
    Vince
  • Greg Beckt
    July 2, 2006 at 6:27 pm
    Thanks for the reply Vince.
    Yes, 1.5.1 is on the machine…Cineform actually suggests keeping it on…plus, I’m still trying to complete a job in 1.5.1.
    I haven’t tried the good old “delete prefs”…thanks for the reminder…I’ll keep attacking this, let me know if anything else comes to mind.
    Greg
