Activity › Forums › AJA Video Systems › Audio stuttering P Pro 5.5.1 & Kona 3
  • Audio stuttering P Pro 5.5.1 & Kona 3
    Posted by Chris Paul on October 25, 2011 at 3:56 pm
    I am constantly getting stuttering audio with Premiere Pro 5.5.1 and Kona 3. I am using the Kona 1080i 29.97 with Canon 1080p video as well as ProRes 1080p video converted to that same format. I am using the 1080i preset because I need to see the HD and NTSC versions at the same time and the Kona 3 does not show both HD and down converted SD at the same time with the 1080p preset. Audio playback via the the computer line output is fine. I am using the Mercury Engine via an NVIDIA GTX 285 card. Same issue when I swap in a Quadra 4000 card or using software acceleration only.
    The audio plays fine via Final Cut 7 which is installed on the same machine.
    Chris Paul
    POV
    Scott Shucher replied 14 years, 6 months ago 3 Members · 7 Replies
  • 7 Replies
  • Walter Biscardi
    October 25, 2011 at 4:00 pm
    Preferences > audio Hardware. Set that to anything OTHER than the AJA Kona.
    Preferences > Player Set that to Adobe
    Walter Biscardi, Jr.
    Editor, Colorist, Director, Writer, Consultant, Author, Chef.
    HD Post and Production
    Biscardi Creative Media
    Blog Twitter Facebook
  • Chris Paul
    October 25, 2011 at 4:18 pm
    Thank you! Completely counterintuitive and worked like a charm.
    Chris Paul
    POV
  • Walter Biscardi
    October 25, 2011 at 4:25 pm
    Yep, I did tutorial video on Vimeo about this. I believe it’s also in the READ ME notes that come with the plug-ins.
    This is all supposed to change when CS6 is released and we get new AJA drivers.
  • Chris Paul
    October 25, 2011 at 4:37 pm
    Yeah, I saw the Read Me- thought it meant that I could not use the Kona 3 for audio playback. Just couldn’t believe that it was true- once again tripped up by my assumptions.
    Thanks again. Hope you are right about CS6. Maybe Adobe will also allow us to have more than one project open at a time.
    Chris Paul
    POV
  • Walter Biscardi
    October 25, 2011 at 5:49 pm
    [Chris Paul] “Maybe Adobe will also allow us to have more than one project open at a time.
    You can. Import > Project. Brings the entire project into a Bin. Double click to open the Bin. Presto, two (or more) projects open at the same time.
  • Chris Paul
    October 26, 2011 at 3:16 pm
    Excellent! Thanks again.
    Chris Paul
    POV
  • Scott Shucher
    March 17, 2012 at 11:31 pm
    Even though this post is several months old, thanks for the tips, here, Walter and Chris. I loaded up Premiere for the first time today for some R&D as an alternative to FCP. Two steps forward one step back was the order off the day, but a start, nonetheless.
