Activity › Forums › Apple Final Cut Pro Legacy › audio stuttering on playback, help!
  • audio stuttering on playback, help!
    Posted by Valerie Hamilton on June 27, 2009 at 2:18 pm
    Distressing audio problem in FCP 6. Video/audio appears to capture just fine, but on playback, often, but not every time, I get audio stuttering. It doesn’t appear to matter whether I’m playing in browser, timeline or print to tape mode, and it happens in a different place every time. Video looks normal.
    Any ideas what would cause this, or how I can fix it?
    Configuration:
    MacBook Pro running OS X 10.5.6 with 2.53 GHz Intel Core 2 Duo processor, 4 GB memory, Final Cut 6. Source video is recorded on a Sony DNW-90 (SX) NTSC 16:9, then played out to capture from a Sony DNW-A220 (SX recorder), composite signal converted through a Canopus ADVC-110 converter with RS-422 device control.
    Settings:
    Capture:
    ADVC-110 using NTSC
    29.97 frames per second
    DV/DVCPRO – NTSC at Best quality
    24 bits per pixel
    640 by 480 (Anamorphic 16:9)
    Using DV Audio for audio input
    Input: first 2 channels
    Format: 48,000 kHz 16-bit 2-chan
    Speaker: off
    Volume 100, Gain 0
    Sequence:
    Frame Size: 640 x 480 pixels
    Editing Timebase: 29.97 fps
    Field Dominance: Lower (even)
    Pixel Aspect Ratio: NTSC – CCIR 601 / DV
    Anamorphic 16:9 : on
    Video Processing: YUV allowed (8-bit)
    White Point: White
    Compressor: DV/DVCPRO – NTSC
    Millions of Colors (24 bit)
    No Data Rate Limit
    No Keyframes Set
    Quality 100
    Audio settings: 16-bit 48.000 kHz stereo
    Device control Presets
    Protocol: Sony RS-422
    Time Source: LTC
    Port: KeySerial1
    Audio Device Control mapping (Ch1-8): 2
    Channels: Frame Rate : 29.97
    Use deck search mechanism
    Pre-roll: 3 secs
    Post-roll: 3 secs
    Capture offset: 0.00 frames
    Valerie Hamilton replied 17 years, 3 months ago 2 Members · 4 Replies
  • Jaap Verdenius
    June 28, 2009 at 9:33 pm
    Why 640×480? I live in a PAL area, but I don’t think that’s NTSC.
  • Valerie Hamilton
    June 29, 2009 at 11:50 am
    Quite right, and I have changed it. Do you think that would affect the audio playback though?
  • Jaap Verdenius
    June 29, 2009 at 12:59 pm
    Yes I think so. Better use the captue/sequence presets that come with FCP.
    Jaap
  • Valerie Hamilton
    June 29, 2009 at 8:03 pm
    OK, that has fixed the problem during playback, but I still have it in print to tape mode. Any ideas?
