Activity Forums Adobe After Effects Audio stuttering on final render
  • Audio stuttering on final render
    Posted by Mike Browning on August 12, 2007 at 10:53 am
    The audio plays back fine when previewed inside AE. The source files are fine too. So after rendering, I get stutters in exactly the same place in the V.O. spots.
    If it makes any difference, I’m running AE 7 Pro, and I’m rendering out using Quicktime and have tried both MPEG-2 and MPEG-4 for compression. Audio is set to stereo 16 bit @ 48khz. These are the settings I use for most renders.
    And while we’re on the subject of audio… a free bonus question:
    Is there also any reason why AE doesn’t recognize most of the .wav files I try to bring in?
    Mike Browning
    U.S. Customs and Border Protection
    Field Ops Academy
    John Dickinson replied 19 years, 1 month ago 2 Members · 1 Reply
  • John Dickinson
    August 12, 2007 at 10:33 pm
    Is the audio an MP3 file? If so, try increasing the AUDIO BLOCK DURATION setting (PREFERENCES > OUTPUT > AUDIO BLOCK DURATION). Make it longer than the duration of the MP3 file and see if that helps.
    JD
    John Dickinson
    Motionworks
    http://www.motionworks.com.au
