Activity Forums Audio Audio Streaming Question
  • Audio Streaming Question
    Posted by Faraz Mozafarian on August 19, 2010 at 8:48 pm
    Hello,
    I am going to be live video streaming a sporting event. We are going to have 2 commentators announcing and I want to be able to stream their audio as well. Is there I way I can plug into their soundboard and wirelessly transmit the audio to my camera. Similar to what you would do with a lavaliere mic?
    John Fishback replied 15 years, 8 months ago 3 Members · 3 Replies
  • Ty Ford
    August 19, 2010 at 9:12 pm
    Hello Faraz and welcome to the Cow Audio Forum.
    Sure, just figure out the gozintas/gozoutas of their console and your camera.
    Why bother to go wireless? I’d stay hardwired just to make life simple. If you MUST be wireless, even a Sennheiser G3 can work. If they only have line out, you needs to get an adapter cable to handle that.
    Get everything well in advance of the broadcast so you can play with it and make sure everything works correctly.
    Regards,
    Ty Ford
    Want better production audio?: Ty Ford’s Audio Bootcamp Field Guide
    Watch Ty play guitar
  • Faraz Mozafarian
    August 19, 2010 at 9:24 pm
    Thanks Ty.
    I want to go wireless because we will be on a boat and the announcers will be on land. I will test everything out and let you know if we run into any problems.
    Thanks Again!
  • John Fishback
    August 20, 2010 at 8:07 pm
    Depending on how far you are from shore, you may need high gain antennas for the wireless to be reliable. As Ty suggests, be sure to test this ship-to-shore in advance of your event.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 3 (FCP 7.0.2, Motion 4.0.2, Comp 3.5.2, DVDSP 4.2.2, Color 1.5.2)
