Activity Forums VEGAS Pro Audio stopped working, what happened?
  • Audio stopped working, what happened?
    Posted by Steve Larson on December 10, 2019 at 12:41 am
    Been using version 12 and 15 for a while now. I use 15 when editing iphone footage. It just seems to handle it better. I worked on a project in 12 the other day then loaded it into 15 ..but when it loaded, there was no audio. You can see the audio meters moving but there is no sound. I tried toggling solo, mute on individual tracks and the master track…but nothing would bring the audio back. I started loading older projects that I edited in 15 ..but when the projects loaded, there was no audio anymore. I went into the audio drivers settings and tried ASIO …at that point, you could hear audio but it sounded like it was coming out of some cheap mono speaker build into the motherboard or something ..but when I switched back to the original driver there was no audio again. I’ve been using 15 almost every day for a year and have never had this issue.
    Any ideas?
    Graham Bernard replied 6 years, 8 months ago 4 Members · 10 Replies
  • 10 Replies
  • Graham Bernard
    December 10, 2019 at 9:03 am
    [Steve Larson] “Any ideas?”
    Hi Steve! This can drive all of us up the bleedin’ wall – and no mistake! What OS Version?
    * Grazie
    PC 10 64-bit 64gb * Intel® Core™i9 – 3.3GHz * 40Gb NVIDIA GeForce RTX 2070
    Cameras: Canon XF300 + PowerShot SX60HS Bridge
  • Steve Larson
    December 10, 2019 at 2:16 pm
    I’m using microsoft 10 home
  • Steve Larson
    December 10, 2019 at 10:48 pm
    I just did a reset on Vegas 15 by holding down SHIFT + CTRL while doubling clicking the V15 Icon. It then brings up an option to reset the settings and also to remove saved data. I tried that, and still no luck. I loaded the program, the whole layout was back to factory default, but audio doesnt work. You see the audio meters working, but just no sound. I instantly loaded up vegas 12, and the sound works perfectly. :/
  • Ole Kristiansen
    December 11, 2019 at 1:50 pm
    Maybe…..
    I Windows 10 – right-click the Speakers icon on the taskbar, and then select Open Volume mixer.
    You’ll see a set of volume controls for your devices. Make sure Vegas 15 is not muted.
  • Ole Kristiansen
    December 11, 2019 at 1:53 pm
    Forgot…. You have to open Vegas 15, and then – right-click the Speakers icon on the taskbar, and then select Open Volume mixer. You’ll see a set of volume controls for your devices. Make sure Vegas 15 is not muted.
  • Graham Bernard
    December 11, 2019 at 3:53 pm
    [Ole Kristiansen] “then select Open Volume mixer. You’ll see a set of volume controls for your devices. Make sure Vegas 15 is not muted.”
    Hi Ole! – Yeah, well I’d also be looking at the SOUND Settings for the Speakers:
    * Grazie
  • Steve Larson
    December 11, 2019 at 6:20 pm
    You are an absolute hero. It worked!! Thank you so much!
  • Graham Bernard
    December 11, 2019 at 6:46 pm
    [Steve Larson] “Thank you so much!”
    Is that mine or Ole’s solution?
    * Grazie
  • Francois Pénzes
    December 11, 2019 at 8:25 pm
    The suspense is killing me….
    PC Win 10 Pro 64-bit 16gb
    Ryzen 9 3900X 12 Core 4.60GHz
    Radeon RX 5700 XT
    Cameras: Canon XF305 + Canon XH-A1
    Vegas Pro 16, User since Vegas 3.0
    \’\’When the cutting stops, the editing begins…\’\’
  • Graham Bernard
    December 11, 2019 at 8:42 pm
    [Francois Pénzes] “The suspense is killing me….”
    Francois, you have NO idea…. I don’t think I’ll be able to sleep tonight ????
    * Grazie
