Activity › Forums › Apple Final Cut Pro Legacy › audio stereo, recorded on 1 chanel. A1 nothing!
  • audio stereo, recorded on 1 chanel. A1 nothing!
    Posted by Tielman Dewaele on May 4, 2009 at 10:25 pm
    Hey,
    Im working on edit, where i suddenly noticed there is no audio in my left speaker. A1= no wave A2= wave (stereo)
    So they recorded it wrong on 1 channel.
    All the interview parts are like that. Is there a way to fix this problem. There is no option to re-record.
    Can someone help me?
    MacPro Intel Quad Core 7G Ram
    MacBookPro Intel Duo Core 2G Ram
    Cs4 Production Premium
    Cinema4D
    Final Cut Studio 2
    Tielman Dewaele replied 17 years, 5 months ago 5 Members · 5 Replies
  • Michael Sacci
    May 4, 2009 at 11:30 pm
    and audio channel A2 (or A-any number) can only be one track. It can be panned to one side of a stereo track or in the middle. If your A2 is just coming out the right speaker you can pan it to the center (0) and then it will come out equally on both sides. But if there is missing audio there is no magic way to bring it back.
  • Bruno Perosa
    May 5, 2009 at 12:36 am
    you could duplicate the good track, replacing the bad one and turn one to left and one to right duplicating the volume of sound (even if it would be mono on 2 tracks and not stereo…)
    EX3, MBP17″2.93GHz, FCS2, Media100, BtcSP, DVcam
  • Alexander Kallas
    May 5, 2009 at 12:38 am
    Hi Teilman,
    You can copy and paste the audio track to another exactly above or below, and adjust either/both as Michael said for your required effect.
    Cheers
    Alexander
  • Rafael Amador
    May 5, 2009 at 1:01 pm
    Hi Tielman,
    I don’t not yet any pro or semi-pro camera that records stereo. Cameras normally records two (or 4) mono channels.
    Recording an interview in two channels is just a matter of security.
    Why you want t put in FC two channels with exactly the same audio?
    One is enough and unless you have recorded the interview too low there is not point in duplicating the track.
    rafa-el
    PS: Professional stereo microphones don’t have an stereo output. They are just two microphones together and they have to be recorded in two mono audio channels. Is to you to pair it as stereo with a mixer or in FC or any other application.
    http://www.nagavideo.com
  • Tielman Dewaele
    May 5, 2009 at 2:30 pm
    ok thx guys,
    I simply used the audio mixer, and as michael sacci said, i needed to put it the stereo centre in the middle, pan it up some. Sounds great!
    Great thx!
    Cinema4D
    Final Cut Studio 2
