Activity › Forums › Apple Final Cut Pro Legacy › Audio Static on Video
  • Aaron Stewart
    February 27, 2008 at 5:22 pm
    Import the audio as .aiff into Sountrack Pro, or do the whole Send thing…
    Highlight a section that ONLY has static, then go to Process > Noise Reduction > Set Noise Print.
    Then highlight the entire audio clip and select Process > Noise Reduction > Reduce Noise
    Play with these settings while previewing the file.
    Also, this sounds like it is mostly pops and clicks, so I would also use the Pops and Clicks filter under the Analysis tab at the bottom left. Check the box, click Analyze, then after it is finished hit Fix.
    Hope that helps,
    Aaron
