Activity Forums Adobe Premiere Pro Audio speed and audio pitch
  • Audio speed and audio pitch
    Posted by Malcolm Desoto on October 17, 2024 at 5:20 pm
    Hey everyone, I’m just trying to increase the speed of an audio clip while maintaining the audio pitch. Normally, I’d Right click and select Speed Duration, set the percent and select “Maintain audio pitch”. This usually works fine, but in Premiere 2024, the audio sounds super artificial with even a 1 percent increase. Is there a better way to go about this?
    Christopher Paul replied 1 year, 10 months ago 3 Members · 3 Replies
  • Rob Ainscough
    October 17, 2024 at 6:28 pm
    You’ll need to separate Audio from Video … assume it’s vocal audio coming from a source not currently visible in the clip? The best pitch processing tool I’ve used is Melodyne Studio version.
  • Malcolm Desoto
    October 17, 2024 at 6:47 pm
    Thank you, Rob. It’s a separate voice over. I’ll check out Melodyne Studio
  • Christopher Paul
    October 19, 2024 at 4:52 pm
    Hi Malcom! Try the audio effects/Time and Pitch/Pitch Shifter plugin that is included in Premiere Pro. It works a lot better than the “Maintain Audio Pitch” checkbox.
