Audio sped up from import via XDCAM Transfer?
Morning guys,
I am using FCP 7.0 and XDCAM transfer to import footage from a Canon XF305 on mac. The footage is playing fine in XDCAM transfer with no problems however when I import to FCP the audio sounds slightly sped up and jarred, it goes out of sync after 1 or 2 seconds although plays fine in the transfer utility. I can’t use the software disc for my FCP which comes with the XF Utility as I am on my own mac to edit some footage together for the contributors of the programme and am transferring the cards using a work laptop which does have the XF Utility programme installed. Worst comes to worst I can ask head office to send up the disc to us but was wondering if anybody has come across this before…
The files and folders are similar to P2, as follows:
CONTENTS > CLIPS001 > INDEX.MIF + 1157 + 1158 + 1159 etc > 1159.CIF, 1159.THM, 1159.XML, 115901.MXF, 115901.SIFAny help would be appreciated. Thanks in advance.
