Audio Spectrum with ultrasound frequency range
Hello, I am new for After Effects and CreativeCow.
I want to create a spectrogram using Audio Spectrum effect, referencing this tutorial.
https://cgi.tutsplus.com/tutorials/the-best-sound-youll-ever-see–ae-3167The beautiful spectrum window in Adobe Audition is ideal. My audio file (.wav) contains ultrasound up to 100 kHz recorded with a special microphone and high sampling rate (250 kHz).
Frequency range I would like to show is between 20 and 100 kHz. However the Audio Spectrum effect has the maximal End Frequency of 22050 Hz, so it does not cover ultrasound range.
Does anybody know how to make a spectrogram of ultrasound?
Alternatively, is it possible to export the spectrum video from Adobe Audition?Thank you so much.
Shimpei
