Activity › Forums › Adobe After Effects › Audio Spectrum Masking to Plexus Lines
  • Audio Spectrum Masking to Plexus Lines
    Posted by Neal Brewer on June 6, 2016 at 11:15 am
    I’m still fairly new, but I’d love to learn a way to mask anything (an audio spectrum in particular though) to the lines generated by Plexus, if possible.
    Michael Szalapski replied 10 years, 3 months ago 2 Members · 7 Replies
  • 7 Replies
  • Michael Szalapski
    June 6, 2016 at 3:33 pm
    When you say, “masking to lines”, what do you mean? You can use the lines as a track matte, but do you mean more like matching motion?
    – The Great Szalam
    (The \’Great\’ stands for \’Not So Great, in fact, Extremely Humble\’)
  • Neal Brewer
    June 6, 2016 at 9:07 pm
    Yes, I do mean more like tracking motion. I’d like an easier way to have an audio spectrum aligned with Plexus lines, other than manually editing each frame, or each couple of frames.
  • Michael Szalapski
    June 6, 2016 at 9:15 pm
    How are you generating those Plexus lines? Are they connecting two nulls together or…?
    – The Great Szalam
  • Neal Brewer
    June 6, 2016 at 9:24 pm
    Currently two or more lights, but let’s use two for now. I imagine I can mask to the space between them, but… You know, new and all. Don’t know how. =/
  • Michael Szalapski
    June 6, 2016 at 9:31 pm
    Tie the end points of the effect to the position of the lights.
    You’d need to use an expression to get a 2d point from a 3d position though.
    Something like
    thisComp.layer("Light 1").toComp([0,0,0])
    (Make sure you change the name of the Light to whatever you’ve named your lights.)
    If you want to do it for multiple lights, you’ll need to use several copies of the Audio Spectrum effect and limit each effect to a particular segment of the audio frequency so that each piece eventually makes up the whole thing.
    – The Great Szalam
  • Neal Brewer
    June 6, 2016 at 10:38 pm
    Doh! You’re absolutely right. I was thinking about pathing, and I completely glossed over the start and end points! Thank you!
  • Michael Szalapski
    June 7, 2016 at 2:48 am
    You’re welcome! 🙂
    – The Great Szalam
