Activity › Forums › Adobe Premiere Pro › Audio source TC burn on image
Posted by Robin Erard on October 28, 2016 at 10:44 amHello,
Is there a way to burn Audio TC (10 tracks) on image ?
Best
Robin
réalisateur, scénariste, monteur, étalonneur
http://www.robinerard.chTrevor Asquerthian replied 8 years ago 7 Members · 7 Replies -
Robin Erard
October 28, 2016 at 3:20 pmHello,
There is a TC and it vary from file to file. Sometime we have 8 sound track at the same time (FX, music, directs). So my idea was to output an offline for the sound editor with Image TC and audios TCs burn in it.
I managed to display these information into viewer (timeline) window, but I can’t find an option to output these informations.
Robin
PS : sorry for my english I speak French.
http://www.robinerard.ch -
Tero Ahlfors
October 28, 2016 at 3:24 pmYou could add a timecode effect and enter the audiotrack timecodes there.
Donna Hufnagel
April 26, 2017 at 6:19 pmCurious if you were able to get this to work? I’m trying the same thing: I need audio source time code burn-ins on a video screener for producers to generate complicated music cue sheets, but I can’t find anyway to select audio tracks for the timecode burn, or any 3rd party plugin for Premiere that can do this.
Zen Rosenthal
September 6, 2017 at 6:13 pmI’m wondering the same thing. Was hoping to burn in the audio timecode for a music track synced to picture.
Bret Hampton
September 6, 2017 at 9:05 pmI think the only way to do this is create a New Sequence and set the TC start to match your source TC. Drop that file into the sequence and add the Timecode effect, then Render a Quicktime, H264 or whatever your client prefers.
Robin
Il faut ajouter la pluart des effets dans le Sequence en Premiere. Je ne connais pas d’autre moyen d’ajouter des effets -
David Cherniak
September 7, 2018 at 3:26 pmCommenting to follow this post.
September 2018 and I still haven’t found a way to burn source TC from audio track.
Any help appreciated.
Trevor Asquerthian
September 14, 2018 at 5:47 am
