Activity › Forums › DaVinci Resolve › Audio Source Name metadata / tc burn
Posted by Ken Filewych on November 19, 2019 at 5:32 pmHello,
Is there a way when syncing video to dual system sound to retain the source audio file name. The minute I sync the files the audio clip name is changed to the video name and I can’t seem to do a burn with the proper name. Is the metadata gone? Does it exist somewhere where it can be accessed and displayed?? Clearly a problem when exporting for post sound at project’s end.
KenDavinci Resolve 15.2.3.015
Ken Filewych replied 6 years, 9 months ago 5 Members · 7 Replies -
Brent Marginet
November 20, 2019 at 1:09 amHave you tried using one of the Custom Text options in the Data Burn-In Window and typing % in the Text Box. Dozens of options will pop up for you to choose and you can concatenate as many as you want together.
\”MY MEDIA/PROJECT MOTTO: If you think three copies of your Media or Projects are enough. Take a moment to place a value on them and then maybe add two more. Hard Drives are now stupidly cheap. A RE-SHOOT AND YOUR TIME AREN\’T.\”
Ken Filewych
November 20, 2019 at 1:34 amWow. That is a function that I did not know existed…. however, it doesn’t help me in this instance. The closest I came was showing Sound Roll # but even that shows incorrectly.
It is so odd to me that in one bin you have your video and audio files and both are correct and have their different Metadata and the second you Sync Using TC, the audio Metadata takes on all attributes of the video clip. The original file in the bin stays the same but the linked audio in the new clip no longer is correct…. crazy.
I know this was a problem many years ago but I figured the would have solved it by now.
Any other ideas out there anyone?????
Ken -
Brent Marginet
November 20, 2019 at 2:33 amYeah it’s pretty cool. The % can also be used in the “Custom Name” box in the Delivery Widow so that you can attach custom names to each and every clip that are dynamic,
Marc Wielage
November 21, 2019 at 6:56 am[Ken Filewych] “Is there a way when syncing video to dual system sound to retain the source audio file name.”
I agree, they need a data field for Sound Reel (aka “Sound File”) and Sound Timecode. These are available in Avid and are part of a standard ALE workflow. Not sure if Premiere has this or not. -
Andi Winter
November 21, 2019 at 5:58 pmlast time i checked, there was this problem, about a year ago.
i am not sure if something changed since then. the ridiculous thing is, when changing to fairlight page, the original sound file name is still there… there is just no metadata option for the export ☹
very silly and strange 🙁
Glenn Sakatch
November 30, 2019 at 8:38 pmThis is the reason i still do all my audio syncing in Avid…(after transcodeing for speed issues) in resolve).
The last thing i need is the sound house yelling at me and having to re-edit the audio to make a proper list.
Glenn
Ken Filewych
December 4, 2019 at 4:53 pmI can’t believe they haven’t “fixed” that yet… crazy missed opportunity.
